It seems Atlassian Intelligence is in beta for cloud services. Is there a plan for server/data center or private instances? If it's not available, are there alternative solutions? Thanks.
Hi @Liang Qu ,
Intelligence is not a simple matter of computing power.
For On premises
Even some subsequent third-party plug-ins may need to interact with third-party Internet service providers for data.
Therefore, I think it is very difficult to implement intelligence through simple local deployment, unless a set of services similar to Chatgpt are separately deployed locally and integrated, similar to the following case
Hi @Liang Qu
Some apps already support this feature, you can try it out.
You can search for "AI" in the "Manage apps" page of your Confluence instance.
Or go to marketplace:
https://marketplace.atlassian.com/search?query=AI+&product=confluence&hosting=dataCenter
