Hi there,
We have upgraded from 2.9.2 to 4.2.13
I used to use this {add-page} macro
{add-page:template=Papers|parent=Papers database|labels=_paper} (+) Click to add a paper in the database (+) {add-page}
which generated this URI
It does not work anymore.
Hi Gerdami,
This is probably a user macro that is no longer compatible with newer Confluence versions, it is very similar to the adaptavist create page plugin: https://marketplace.atlassian.com/plugins/com.adaptavist.confluence.createpage
Can you give this plugin a try and see if it fits your needs?
Cheers
Help us plant more trees
