bash: sudo: command not found
Andrey Pykhantsev November 2, 2018
can't seem to go past this step when installing the trial version
I am trying to install confluence trial following instructions at https://confluence.atlassian.com/doc/installing-a-confluence-trial-838416249.html on mac/linux, have jdk installed and looks like i have the rest of the requirements up as well.
I'm stuck on step 2.2: Install Confluence -- Run installer.
When I run the suggested command "
$ sudo ./atlassian-confluence-6.12.1-x64.bin"
i get "command not found" and can't get the installer to run.
Any suggestions?
Thomas Deiler
Dear @Andrey Pykhantsev,
has the executable mode 755 at least? If not either you do following
$ sudo chmod 755 atlassian-confluence-6.12.1-x64.bin
or
$ sudo sh atlassian-confluence-6.12.1-x64.bin
So long
Thomas
Like • 2 people like this
Thomas Deiler
if you would like the community assisting you, I recommend to provide more details than 17 words.
Thanks for understanding
Thomas
