code-block in a bullit list does no longer indent after upgrading to Confluence 4
Andre van der Elst
I'm trying out Confluence 4 to see if the new editor is indeed less buggy than the previous.
I used to have bullet lists with code blocks in some bullits (to detail steps to take, for example an SQL query)
Any page that I haven't edited in the 4.0 editor display fine, but if I edit a bullit with a code block it will indent to the left, no clicking on left/right in the menu bar will line-up the block as it used to be.
The screenshot shows my issue in editing mode, the top code block is neatly positioned beneath the text, the bottom one I accidentally edited and now I can't get it back to where I want it. It's not just misaligned in editing mode but also when viewing the page.
Can I align code blocks in a bullit list like I used to do in Confluence 3.x ?
6 votes
HuseinA
November 12, 2011
Try the following:
  1. Click on the bottom code block icon to select the whole code block, then cut it (Ctrl + x).
  2. Place the cursor to the end of the second bullet line (eg. '...database')
  3. Pressh Shift + Enter
  4. Paste it (Ctrl + v)
  5. Voila?
As described here, You can use 'Shift + Enter' to create a new line without having a new bullet or exiting from the bullet list.
Mike Cavedon
October 3, 2013
Excellent answer. Straight and to the point. Thanks.
atlassian, confluence, marketing templates, confluence templates, marketing project management, content strategy, campaign planning, marketing collaboration, confluence for marketers, atlassian learning, marketing workflows, confluence best practices
5 must-use templates for Marketing teams (from a Confluence Marketer!) 👩🏻‍🎨
Read more 📚
