Hey,
I have a form with some data (text and dropdowns) and I want use the filter control to filter the table. I will try to explain my problem:
I filter for the text field and I got the results in a table. If I now additionally filter for the dropdown field it shows me all values in the filter menu, also the data which is no longer "availabe" because it's filtered out by the text filter.
I ask for a filter feature that shows only the filte roptions for the current view and not the whole data. In the end, I want avoid that the result of filtering the table shows no data.
I hope you understand what I am searching for?
Fields in the filtering control macro cannot be configured dependent at the moment
Alex
Okay, sad...so I have to find a way in combination with the confluence table filter. Btw. what means "Show only relevant choices on dropdown"?
Example: Why the filter show all 4 possible colors and not only the relevant choices? I saw there is an option to set "Show only relevant chocies on dropdowns", is that not exactly what I searching for? If yes, it seems not to work properly.
