confluence and ldap authentication
Alex Samad YB March 8, 2012
Hi
I am planning for installing confluence and using a ldap db for my users. just wondering how confluence authenticates users, does it do a ldap bind with the relevant user and password ?
What my setup is going to look like is, I have AD (say abc.com). I was going to setup a linux box running openldap so that i could create none AD users (our customer in here, why I don't want to pay for 000s of CAL licenses and I believe the MS connector license is prohibative but not ruled out. ) so all the clientes were going to exist in external.abc.com
do my ldap would look like
dc=abc,dc=com
ou=external,dc=abc,dc=com
DN's for AD look something like CN=alex samad,ou=abc,dc=abc,dc=com
where as DN's for clients could be something like
CN=<emailaddress>,ou=external,dc=abc,dc=com
Am I going to be able to configure confluence to handle that ?
Alex
Andrew Frayling
March 11, 2012
Hi Alex,
Yes, Confluence can use multiple LDAP sources so you can configure as many LDAP sources for users as you wish. Have a look at http://confluence.atlassian.com/display/DOC/Managing+Multiple+Directories for details.
Using email address to log in should be fine as you configure Confluence to tell it what LDAP attribute to use for username, first name, surname, etc. Have a look at the USer Scheme Settings section at http://confluence.atlassian.com/display/DOC/Connecting+to+an+LDAP+Directory for details of what LDAP attributes Confluence asks you to map.
For the last question, as far as I am aware, Confluence doesn't sync the LDAP password locally and test against the sync'ed copy, it tests against LDAP directly.
Does that help?
Andrew.
Andrew Frayling
March 8, 2012
Hi Alex,
For binding to LDAP Confluence can use either a single user or anonymous bind (if your LDAP is configured to allow anonymous bind) depending on whether you supply values for "Username" and "Password" in the LDAP config in Confluence.
If I'm understanding the second part of the question correctly, you only want Confluence to allow access for users in external.abc.com and not for users in abc.com? If that's the case then that's not a problem with Confluence as in the LDAP config you supply a base DN and Confluence will only look for users in that container and below, so if you set your base DN in Confluence to ou=external,dc=abc,dc=com then only users in that container and below will be able to log in.
For licensing in general a user counts against your Confluence license if they have the "Can Use" permission, so if you have 10,000 users in LDAP, but your Confluence LDAP is configured so that Confluence can only see 50 of them then that would be 50 against your license, not 10,000. Does that make sense?
For LDAP config have a look at http://confluence.atlassian.com/display/DOC/Connecting+to+an+LDAP+Directory
Hope that helps,
Andrew.
Alex Samad YB March 11, 2012
Hi
Thanks, slight mis understanding.
I would like to allow users from
* internal - from our own AD server
* external - this was to be managed from openldap
I would like people to login as email address, So
alex.samad@abc.com (pretend abc.com is my ad domain) would translate into a ldap request to ldap.abc.com with ????
alex.asmad@xyc.co.uk (external client), would translate into a ldap request to ldap.abc.com
But to add more confustion (as i have read some documentation). It seems like I confluense can use multiple LDAP sources ? so I don't need to hid my AD ldap tree behind openldap !
The other question is how does confluence check userid password.
alex.samad@abc.com (internal user), the DN for this user is not alex.samad@abc.com, does confluence search for the this user and retrieve the password and test its self or does it find the user and then find its dn and then get ldap to test the password ?
Alex
Andrew Frayling
March 11, 2012
Hi Alex,
Does that help?
Andrew.
Alex Samad YB March 12, 2012
Yep I think thats what I am after...
some more planning and a trial :)
Register today
