conversion program installation on Confluence server for Visio Plugin for Confluence
John Alton
What is an acceptable "conversion program" that needs to be installed on the Confluence server, to enable the Visio Plugin for Confluence to automatically convert the file to SVG format when IE rendering is not available?
[Taken from the comment "(requires conversion program installation on Confluence server)"]
thanks,
john
Sean King
September 5, 2013
The Gliffy Plugin gives you the ability the use and edit Visio files in confluence.
New Confluence Admin Learning Path! 🤩
Confidently manage users, permissions, and content in Confluence. This self-paced learning path helps admins streamline collaboration, improve user experience, and apply the best practices to get the most out of Confluence in any cloud environment.
Start Learning Now
