create dialog loading forever
Kevin Tan July 4, 2019 edited
I encounter this problem - "create dialog loading forever" after upgrade to latest confluence server (6.15.6) with postgresql 9.6. i also cross checked google and atlassian community , can't find solution for my case although someone might having similar issue but i can't see the same error from my log file.
Here is the post that i had checked and doesn't looks like is my case,
  1. https://confluence.atlassian.com/confkb/after-upgrading-confluence-you-are-unable-to-create-new-pages-or-spaces-785457379.html
  2. https://confluence.atlassian.com/confkb/create-space-dialog-loads-indefinitely-586875930.html
  3. https://confluence.atlassian.com/confkb/unable-to-create-pages-or-spaces-the-popup-loads-forever-after-confluence-upgrade-to-5-x-or-6-x-330793034.html?_ga=2.188700008.1370675637.1561809388-623873729.1561562947
Screenshot 2019-07-04 at 7.03.59 PM.png Screenshot 2019-07-04 at 7.04.43 PM.png
