I would like to edit a Confluence macro but i can't find where it is stored. I don't mean an user macro but those macro that come out-of-the-box with installation. Could you help me, please ?
thanks in advance
Nico
Most of the built-in macros are bundled into "system" add-ons. You'd need to get the source code of those, make your changes and recompile them, then deploy them to your server, replacing the system add-on.
thanks Nic. For example, suppose I need the source code of "contentbylabel" macro.
As you told I found the addon "Advanced Macros" and inside the module "contentbylabel" but I can't find the source code.
Do you have more details, please?
