I have this error in the question's title.
I can not figure out what can be wrong.
OS: CentOS 7
domain name is not real and therefore you see server.domain
Here is my settings for server.xml
<Connector port="7991" relaxedPathChars="[]|" relaxedQueryChars="[]|{}^\`"<>"
maxThreads="150" minSpareThreads="25" connectionTimeout="20000" enableLookups="false"
maxHttpHeaderSize="8192" protocol="HTTP/1.1" useBodyEncodingForURI="true" redirectPort="8443"
acceptCount="100" disableUploadTimeout="true" bindOnInit="false"
scheme="https" proxyName="server.domain" proxyPort="443" secure="true"/>
<Connector port="7992" relaxedPathChars="[]|" relaxedQueryChars="[]|{}^\`"<>"
acceptCount="100" disableUploadTimeout="true" bindOnInit="false" scheme="http"
proxyName="server.domain" proxyPort="80"/>
apache conf file content
<VirtualHost *:80>
ServerName server.domain
ProxyRequests Off
ProxyVia Off
<Proxy *>
Require all granted
</Proxy>
ProxyPass / http://127.0.0.1:7992/
ProxyPassReverse / http://127.0.0.1:7992/
RewriteEngine On
RewriteCond %{SERVER_PORT} !443
RewriteRule ^(/(.*))?$ https://%{HTTP_HOST}/$1 [R=301,L]
</VirtualHost>
<VirtualHost *:443>
SSLProxyEngine on
SSLEngine on
SSLCertificateFile /home/centos/.cert/key.crt
SSLCertificateKeyFile /home/centos/.cert/key.key
ProxyRequests off
ProxyPreserveHost on
<Proxy *>
Order deny,allow
Allow from all
</Proxy>
ProxyPass / http://127.0.0.1:7991/
ProxyPassReverse / http://127.0.0.1:7991/
</VirtualHost>
The Base URL is `https://server.domain`
What I need to do to make it work over https?
The problem is not exist at all over http however I still use proxy
Thank you
Hi @Laszlo Varga ,
Please check, is your base URL is correct? If no correct it by System -> General Configuration and then try.
Furthermore, you can have a look at similar articles which may help you,
gadget-common-error-500-LAN-DNS-no-https
Ram.
Hi Ram,
The Base URL is correct.
I have gone through many forum thread and tried to fix this issue.
I have rebuilt the server.xml from default and apache vhst conf file from scratch following the atlassian instructions.
As I also mentioned there is no problem over http and use proxy.
In the question, mentioned that the base URL https://server.domain and which is linked to other URL.
Please try with the base URL in the link if that is the correct base URL and let us know, how it goes.
I used server.domain as a placeholder because I did not want to expose it
@Laszlo Varga @Rambabu Patina {Appfire} Has this been solved? I am also having the same issue. And nobody else on the forums knows the exact answer. :(
