generate a report of confluence spaces and their permissions
Thomas Burke
We are in process of  cleaning up  spaces  particularly  those with no restrictions.
Is there a report of sorts  I can generate to show me all my spaces and type of restriction in place  and what  groups / users are permissioned to spaces?  Thank you in advance!
Brant Schroeder
Thomas,
  You can use do this help article to get the information you are interested in https://confluence.atlassian.com/confkb/how-do-i-view-a-list-of-all-space-administrators-for-all-spaces-346325879.html
If you use the macro you can change the canAdminister to canView.
Additional information about permission helper can be found here: https://docs.atlassian.com/DAC/javadoc/confluence/4.0/reference/com/atlassian/confluence/security/PermissionHelper.html
Thomas Burke
Hello thanks  but  is not really what I asked.  Is not a list of spaces restriction settings and all groups /users,  just space admins.  I already know what they are.  I fear this migh not be the right forum  for question like this.  thanks though
Brant Schroeder
You can make adjustments to the macro or SQL to get that information you are after.  Space admin is the example.   You can use any of the items in the API reference including SpacePermissions:  https://docs.atlassian.com/DAC/javadoc/confluence/4.0/reference/com/atlassian/confluence/security/SpacePermission.html
Learn more
