how does the [ ] shortcut work for a task list?
Margaret Boeneke October 15, 2018
I see documentation that you can use [ ] as a shortcut for a task list, but no matter how I enter it, i get a shortcut to create a link. what exactly am I supposed to type?
Thomas Schlegel
October 15, 2018
Hi @Margaret Boeneke,
just enter
and then
without any spaces or anything else between these brackets. That should result in something like this:
it is not working at all. is this possibly a version problem? We are using server 6.10.1
instead of allowing me to do the task list shortcut, it is doing a link autocomplete like this:
Thomas Schlegel
October 15, 2018
Do you get this, when you enter the opening bracket?
What happens, if you then enter the closing bracket?
Thomas Schlegel
October 15, 2018
I see, you get this.
Then, just ignore the suggestions and enter the closing bracket instead.
that just makes brackets :(
Like Rebekah Nguyen likes this
Thomas Schlegel
October 15, 2018
Don‘t put anything between the brackets and enter a space after the closing bracket
Like # people like this
that worked!! thank you!!
Thomas Schlegel
October 15, 2018
That‘s great, @Margaret Boeneke, you‘re welcome
If you think, your question is answered, please accept the answer with the green button above. Other users with similar questions can find answers easier, if they are accepted.
Thank you
Thomas Kanusky
April 22, 2020
[space] doesn't seem to work now 22 April 2020.
Anyone else have this problem or know a solution?
Mallee Morris
I also can't get my keyboard shortcut to work for action items...can't add them in line by  starting with @User Issue //date either.  That inserts the user tag and the date but doesn't register it as an action item.
