how to get macro usage report for confluence 5.1.3
Rinku Saha October 31, 2014
Earlier version of confluence we run the report for different macro usage. Right now we are using confluence version 5.1.3, how to get the same report.
as an examaple we using run the query like below . Please suggest. it really and urgent requirement.
SELECT b.BODYCONTENTID, b.BODY, b.CONTENTID, c.TITLE , c.VERSION, c.CONTENTTYPE, c.SPACEID,  sp.Spacename, sp.SPACEKEY FROM BODYCONTENT AS b INNER JOIN [CONTENT] AS c ON b.CONTENTID = c.CONTENTID INNER JOIN SPACES SP ON SP.SPACEID=c.SPACEID WHERE (b.BODY LIKE '%{macroname%')
 Thanks'
Rinku
Davin Studer
October 31, 2014
The problem is the b.BODY LIKE '%{macroname%'. You need to specify the new storage format for macros. It should look more like this.
SELECT
	b.BODYCONTENTID,
	b.BODY,
	b.CONTENTID,
	c.TITLE,
	c.VERSION,
	c.CONTENTTYPE,
	c.SPACEID,
	sp.Spacename,
	sp.SPACEKEY
WHERE (b.BODY LIKE '%<ac:structured-macro ac:name="macroname">%')
Patrice Foerster November 5, 2015
That's exactly what I was looking for. Thanks, mate!
Davin Studer
November 5, 2015
If you are on a newer version than 5.1.3 then you could use the user macro that I created at the below address. It is better than the above query. It requires at least Confluence 5.5. http://iamdav.in/2015/01/06/confluence-macro-usage-report/
Rodrigo Girardi Adami
October 31, 2014
Hi Rinku,
As far as I know, this query shows all pages that uses this macro. Unfortunately confluence doesn't have a bundled functionality to show the macros.
The query that you listed will work to show the pages that uses the macros.
Rodrigo
Help us plant more trees
