×We usually use the following simple user macro:
## @param PageId:title=Page Id|type=int|required=true|desc=The ID of the page #set ( $Integer = 0 ) #set ( $pageId = $Integer.parseInt($paramPageId) ) #set ( $page = $pageManager.getPage($pageId) ) Is favourite? $page.isFavourite($action.remoteUser)
Hope this helps
You can do this via database:
select * from content_label where labelid IN (select labelid from label where namespace = 'my' AND name = 'favourite') AND contentid = INSERT-PAGE-ID-HERE;
Remember to change the INSERT
-PAGE-ID-HERE
accordingly.
If there is no row returned, page is not favourited.
Or you write a little usermacro which you can use on every page
## @param pageId:title=pageId|type=int|required=true|desc=Insert the pageId #set($Integer = 0) #set($parampageId = $Integer.parseInt($parampageId)) #set($pageById = $pageManager.getAbstractPage($parampageId)) #if($pageById) #foreach( $label in $pageById.labels) #if($label == "my:favourite") #set($isFavourite = true) #break #end #end This page is #if(!$isFavourite) not #end a favourite page. #else No page found! #end
both good answers ;-)
