how to run a jython script - missing modules
Erik Zaroban
September 7, 2011
Hi there,
I have a problem running a jython script with the buildin python modules socket and pickle.
In the shell the script works fine and connects to the daemon on another server. So the modules are installed:
The script lies under [...]/confluence-data/script/ and can be executed via confluence with this command
{jython:output=wiki|script=#script.py}
{jython}
For a testing "Hello World" this works fine to call the script, but when I want to use the mentioned modules, they can't be found.
Traceback (innermost last):
File "<string>", line 2, in ?
ImportError: no module named socket
Does anyone has a clue how to get it working, how to explicit import the modules in confluence?! It would be nice to have this functionality in confluence.
Cheers
Erik
Bob Swift
September 7, 2011
See SCRP-119 comments for instance. I think you need to install whatever libraries you want to use in WEB-INF/lib.
Erik Zaroban
September 7, 2011
Ok, thx I will try that for the next change.
atlassian, confluence, marketing templates, confluence templates, marketing project management, content strategy, campaign planning, marketing collaboration, confluence for marketers, atlassian learning, marketing workflows, confluence best practices
5 must-use templates for Marketing teams (from a Confluence Marketer!) 👩🏻‍🎨
Read more 📚
