Hello Team,
I have upgraded confluence From 4.3 to 5.1 and then 5.2.
But for 5.1 i have not checked all the plugins compatibility.
upgradation is successful. But whenever i am searching in confluence search its throwing below error.
Java.lang.IllegalStateException: field "title" was indexed without position data; cannot run SpanTermQuery (term=resource)
at org.apache.lucene.search.spans.SpanTermQuery.getSpans(SpanTermQuery.java:129)
i have recreated indexes from scracth, Rebild all indexes, disable all custom plugins and but this error is still in system.
please let me know your suggection how i can fix this issue.
Thank you,
Tousif
Hello Tousif,
I do believe that something went wrong with the upgrade after 4.3. Have you tried to revert and upgrade Confluence again, but before that removed the third party plugins from Confluence to make sure that there aren't compatibility issues caused by them?
I recommend to:
1) Backup Confluence database and try to remove all third party plugins from the instance by running the following commands:
2) If the issue persists, there is some corruption caused by the upgrade. Try to restore the 4.3 version into a staging instance and perform a new upgrade without all third party plugins and check if that resolves.
Rodrigo
Register now
