is it possible configure two identical AD in Confluence
Davida February 24, 2022
Hello everyone
Today we have had a problem accessing the AD due to a certificate issue that we have solved by pointing to a second active directory identical to the first
We currently have two identical LDAP with distinct domains in our company and I wanted to know if we can configure both in our Confluence access as two directories in case one fails, use the other.
The confluence user would have to remain independent of which of the two domains/directories is accessed
Best regards
Radek Dostál
February 24, 2022 edited
Authentication is first in order depending on where the user trying to log in exists. To make use of both ext. directories, each user would need to have an account in both of them.
So when you're logging in, Confluence "scans" directories top to bottom and authenticate you against the first match. This means that you will always be using the first directory you have your user in. Regardless of whether that directory times out or fails. The failover/redundant AD support is on the roadmap - https://jira.atlassian.com/browse/CONFSERVER-8867
I believe you would be able to set this up in Crowd, at least from initial looks, just not in Confluence out of box https://confluence.atlassian.com/crowd/configuring-directories-for-failover-authentication-890749126.html
Nic Brough -Adaptavist-
February 24, 2022
This won't work - Confluence considers each directory you configure as a different source.  So even if they are the same, "directory 1: nic" would not be the same user in Confluence as "directory 2: nic"
You can't use Confluence's directories for directory fail-over (yet)
You need to do one of
  1. Implement failover recovery on the directories, not Confluence
  2. Use something that abstracts the directories away from Confluence
  3. Wait for failover to be implemented in Confluence
Points 2 and 3 here are better explained by @Radek Dostál
atlassian, team ’25 europe guide, teamwork collection, atlassian events, conference guide, team culture, collaboration tools, ai in teamwork, atlassian learning, event schedule, keynote previews, community events
Must attend events for Team Europe '25!
Make the most of your time in Barcelona with our curated guide – discover how Jira, Confluence, Loom, and Rovo work better together, connect with Atlassian experts, and enter to win an Apple prize bundle!
Get the guide
