java.io.IOException No space left on device
Nick Dring
Hi
In Confluence daily log email I got this error.
How do I check the disk space? I can only see the VM memory in the system info.
Pavel Potcheptsov
November 6, 2016
In Linux:
# df -h
Will show you totals.
# du -sch /*
Will show you totals per directory.
Nic Brough -Adaptavist-
November 6, 2016
You'll need to log into the server on the command line or use monitoring or access tools.  You'll need to do that to free up space anyway.
