jira macro caching issue
B. Normann P. Nielsen
September 27, 2012
I have a Confluence connected to a JIRA and Application links looks fine.
The JIRA Macro has Cache turned off, but still it is random what I do see in the Macro, mosly
JIRA Issues (0 issues)
But somethis it correctly - shows the issues. Clicking the JIRA Issues links always brings me to the JIRA showing the correct items.
The 2 instances does not have common userbase, but the username/passwords are the same.
Why does this seemeed cached still. I am pretty sure the "problem" lies on the Confluence side, not JIRA.
Harry Chan
October 1, 2012
Hi, you can go to Confluence->Browse->Confluence Admin->Cache Statistics to see what is being cached.
There is an item called "JIRA Issues". If you click on Display: Advanced, you can edit this cache as well. If you want all JIRA Issues Macro to not be cached, simply set this to 0.
Also, if you want to change things like expiry time etc advanced features, use the ehcache.xml in Confluence.
Johannes
December 13, 2019
Hello @Harry Chan5, hello @B. Normann P. Nielsen,
have you found a solution for the recent Jira / Confluence versions? We are using Confluence 6.13.8 and Jira v8.5.0 and this seems to not work anymore.
The GUI simply does not allow a value below 1.
I tried to set the value manually to 0 in the created cache-settings-overrides.properties and restarted the server. It still doesn't work.
Normann P_ Nielsen _Netic_
December 13, 2019
Use
<ac:parameter ac:name="cache">false</ac:parameter>
Its not a GUI options, so the page source need to be edited  use https://marketplace.atlassian.com/apps/1215664/source-editor-for-confluence?hosting=cloud&tab=overview
So the complete macro is like:
<ac:structured-macro ac:name="jira">
<ac:parameter ac:name="columns">Summary,key,Reporter</ac:parameter>
<ac:parameter ac:name="server">Netic JIRA</ac:parameter>
<ac:parameter ac:name="maximumIssues">1000</ac:parameter>
<ac:parameter ac:name="serverId">1b92b7a9-e280-3ff3-9ef9-1d9585f4e0cb</ac:parameter>
<ac:parameter ac:name="jqlQuery">status not in (Resolved,Closed,Frozen)</ac:parameter>
</ac:structured-macro>
Try setitng in a few JIRA Macros in a page, save, edit and investigate them via the Source Editor
Like Johannes likes this
Johannes
December 13, 2019
Thank you very much!
