I want to display lively blog posts in several tabs on one single confluence page. If the lively blog post is not on the active tab (the tab that is showing by first loading the page), lively blog post is not displayed correctly: image2016-9-28 8:59:12.png
Switching between the tabs is not fixing the problem.
Only when I fade in the confluence sidebar lively blog post is displayed correctly:
image2016-9-28 9:5:52.png
As soon as I fade out the sidebar the problem is still fixed.
Hi Mark, yes your're right, thanks for pointing this out. This is an issue within the Lively Blog Post Plugin which we will fix it and put it into the next release as soon as possible!
