logAncestorsTableFailure after create spaces and pages in Confluence
Orkun Gedik March 22, 2018
I am working on a confluence plugin which creates spaces and pages via Java API. When I check my confluence-logs, I am facing with an log on ERROR level;
ERROR [http-nio-6700-exec-2] [persistence.dao.hibernate.HibernateContentPermissionSetDao] logAncestorsTableFailure Detected ancestors table corruption for pageId: 1901470. Access to this page is blocked for all users as inherited permissions cannot be determined. To resolve this, rebuild the ancestors table. See https://confluence.atlassian.com/display/DOC/Rebuilding+the+Ancestor+Table
 I have no idea why I am taking this error. Any suggestions or tips will be helpful.
Madhusudhan Matrubai
Probably this https://confluence.atlassian.com/doc/rebuilding-the-ancestor-table-153948.html can fix your problems.
Good luck..
Madhu
Deleted user August 16, 2018 edited
We are experiencing the exact same issue.  It happens again every time after rebuilding the ancestor table so that is not solution.
@Orkun Gedik Did you find a workaround or some other solution?  I am saving like this for new pages:
    glossaryPage.setBodyAsString(sb.toString());
    pageManager.saveContentEntity(glossaryPage, null);
And like this for pre-existing pages:
    SaveContext saveContext = DefaultSaveContext.DEFAULT;
    pageManager.saveContentEntity(glossaryPage, oldGlossaryPage, saveContext);
There is also this critical bug reported: CONFANCESTORS table obtains duplicate record after a page page re-order to space root
which i cannot reproduce, but it may be related.
Confluence 6.6.7, clean install, local ATLAS developer instance, no other plugins/add-ons installed.
Deleted user December 19, 2018
I solved this problem by explicitly setting many fields of the Java objects for the new page relating the space, page and parent page, such as setting the parent of the child and child of the parent, space of the child, etc..
4 votes
Antonio Dionisio
I had the same problem when creating the pages programatically. I have found that calling this method after the child page creation fix the problem:
pageManager.updatePageInAncestorCollections(page, parentPage);
Adrian Moerchen
December 1, 2020
There is something wrong, if there is a method explicitly for this...
I also had to call
parentPage.addChild(page);
