merge users
Craig Newbury April 19, 2015
Mallmann
April 20, 2015
Hey Craig,
May I ask you to describe a bit what you're trying to achieve here? For example, if you have two Confluence instances that you want to merge users only, or if any of the instances has a LDAD, etc.
A description of your set up and what you want to do will be very helpful to understand the question. smile
Eduardo
Ansar Rezaei
April 20, 2015
I faced with this problem before. We use JIRa Internal User directory at first and then we wanna to use OpenLDAP beside Atlassian Crowd for all systems in company and we had to merge old JIRA internal users with new LDAP users to in order to keep the history of activities for each users. It really boring for me sad
Try Script Runner plugin smile. It has  a good built-in script for doing that wink
Guilherme Nedel [Atlassian]
April 20, 2015
Craig, this thread is empty in content, it just has the title. Please add your query here, otherwise we will need to close this query.
