Hi folks:
I've found a lot of examples in the internet how to access any kind of java classes via .class.forName. I've tested this in my user macro:
#set ($string="")
#set ($base64=$string.class.forName('java.util.Base64'))
<pre>
base64: $base64.getClass()
</pre>
that results in "$base64.getClass()" and not as expected in "java.util.Base64".
An implicit initialization with "newInstance()" has changed nothing.
#set ($base64=$string.class.forName('java.util.Base64').newInstance())
Has someone an idea, what's wrong here?
I'm using Confluence 7.4.0 Server.
Hi René,
I just ran across the same problem. Have you found a solution in the meantime?
Ulrik
Hi René,
meanwhile, I found a posting that gave me the impression that the option of using "object.class.forName()" has gone for security reasons. :-(
Ulrik
Want to leave your mark on Confluence? One winner will have their whiteboard design added into Confluence for all users to access! This is your chance to showcase your creativity, help others, and gain recognition in the Confluence community.
Share your template today!Online forums and learning are now in one easy-to-use experience.
