page breaks in pdf's
Gedalyah Geller August 31, 2011
How can I control page breaks when creating a pdf?
Kim Tillett
Worked like a charm!
Like Jeff Tillett likes this
muschol
We had the same problem with Confluence, and we wrote a user macro to solve this.
Just go to Confluence Admin->User Macros and add a new Macro.
Give it a name (e.g. pagebreak), make sure it's visible to all users and you have No Macro Body selected. Then put the following in the macro body:
## Macro name: pagebreak
## Has body: NO
## Generates: HTML markup
<div id="pagebreak" style="page-break-before:always;"></div>
You can then insert the page break macro on your pages, wherever you want a page break in PDF.
Hope this helps.
Matt
Martin Gregory
My Confluence Admin doesn't even _have_ a "User Macros" section! :(
Like Irina Gershun likes this
Greg Turnbull October 12, 2015
Does not work in V5.8.4
Charles Ritchea December 10, 2014
This might not be perfect, but it was the only way I could do it with limited permissions.
Insert a page break: A line with Heading 1 style and a non-breaking space. Use the Insert / Symbol menu and pick the first empty area. You can't use normal space as it will get removed as well as the line when you save.
Configure Table of Contents: Exclude \u00A0 to filter out all headings containing non-breaking space.
Martin Gregory
I don't get page breaks before H1s, so I guess this isn't going to work?
Robert Imhoff August 19, 2014
The new confluence requires that a param be defined for it to be visible. Below code did the trick for us.
## Macro title: pagebreak
## Macro has a body: N
## Body processing: Selected body processing option
## Output: Selected output option
## Developed by: YOUR NAME
## Date created: 19/09/2014
## Installed by: YOUR NAME
## @paramBreak:title=break|type=string|desc=default value|required=false|multiple=false|default=always
<div id="pagebreak" style="page-break-before:$paramBreak;"></div>
Neeraj Tiwari September 30, 2014
Hi, I tried your suggestion but it still gives me the below error: There are user macros without any metadata configured in their template. They have been highlighted below. For these macros to be available for use in content they require parameter information. See the Guide to User Macro Templates. Can you verify if our code is good: ## Macro title: pagebreak ## Macro has a body: N ## Body processing: Selected body processing option ## Generates: HTML markup ## Output: Selected output option ## ## Developed by: NEERAJ TIWARI ## Date created: 09/30/2014 ## Installed by: NEERAJ TIWARI ## @paramBreak:title=break|type=string|desc=default value|required=false|multiple=false|default=always <div id="pagebreak" style="page-break-before:$paramBreak;"></div>
Annette Beckett July 10, 2015
## Macro title: pagebreak ## Macro has a body: N ## Body processing: Selected body processing option ## Generates: HTML markup ## Output: Selected output option ## ## Developed by: YOUR NAME ## Date created: 19/09/2014 ## Installed by: YOUR NAME ## @param Break:title=break|type=string|desc=default value|required=false|multiple=false|default=always <div id="pagebreak" style="page-break-before:$paramBreak;"></div>
Parth Shah October 2, 2015
I added this snippet. What do I insert at the place where I want the page break to happen? Meaning how do I get the desired page break at the desired location after adding this code in the PDF stylesheet.
JenniferC September 5, 2011
Similar to the previous post - with the Content Formatting plugin installed, we simply use on the wiki page:
{div:class=pagebreak}{div}
In the PDF stylesheet (although I guess this could go in the global/space stylesheet?) we'd have:
div.pagebreak {
page-break-before: always;
You could also set the CSS to any element on the page... like h1 headings, which makes sense for reports.
Jean de Laulanié
September 4, 2011
have a look to this page http://confluence.atlassian.com/display/DOC/Editing+the+PDF+Stylesheet
works fine with Confluence version 3.5.x too.
Martin Gregory
This link no longer exists in the Confluence documentation. Did they take this feature away?
