page restriction setting for group add
Anderson Hsu
Dear Support Team,
After add page restriction for group add, we found we must run rebuild index ,and then the setting can work . So we would like to make sure is there cron job for rebuild index?
And we also found when some group is removed at ldap , but the same group at the page restriction is still exist. Would it be possible to automatically remove the same group at the page restriction while the group was deleted at ldap?
Thanks a lot.
Best Regards, Anderson Hsu
Fabio Racobaldo _Herzum_
April 30, 2022
Hi @Anderson Hsu ,
reindexing is something that happens periodically so you don't need to perfom manually.
https://confluence.atlassian.com/doc/scheduled-jobs-96567525.html
Hope this helps,
Fabio
