pdf. displaying quality.
gredwhite
November 15, 2013
I want to add pdf file to my page.On my computer all symbols are readable at this pdf file. But when I add this pdf to page I cannot read this pdf(even in full screen mode)
Can you help me to solve this problem?
I use Confluence 5.1.version
Pedro Rodrigues June 25, 2014
The Link Preview (https://marketplace.atlassian.com/plugins/com.xpandit.plugins.linkpreview-confluence) is a great Confluence Utility. You can preview PDF documents, images and webpages.
Try it now.
Best Regards,
PMRodrigues
arron lee January 9, 2014
Hi, Nikolay.
As for myself, I learning about how to create document viewer, such as PDF viewers, with the help of some manual tools which can be customized by users according to our own favors to help display and read PDF files these days. You can also google it and select one whose way of processing is simple and fast to help you with the related work. Remember to check its free trial package first if possible. I hope you success. Good luck.
Best regards,
Arron
Patrice Rompas
January 5, 2014
Hi Nikolay,
Currently, there are a lot of improvement requests regarding PDF viewer quality. But there hasn't been direct fix on that thus the only way to view PDF with the best quality is to download the PDF itself. However, you can try using third party plugin such as SharpView High-Resolution PDF Viewer for Atlassian Confluence. It supports Confluence 5.1 version.
Samuel
Register now
