Getting error on setup:
db url: jdbc:postgresql://localhost:5432/confluence
Can't reach database server or port
SQLState - 08001
org.postgresql.util.PSQLException: Connection to localhost:5432 refused. Check that the hostname and port are correct and that the postmaster is accepting TCP/IP connections.
I'm able to connect to db from linux command line.
$psql -U confluenceuser -p 5432 confluence
pg_hba.conf
#local all postgres peer
local all all md5
# TYPE DATABASE USER ADDRESS METHOD
# "local" is for Unix domain socket connections only
local all all peer
# IPv4 local connections:
host all all 127.0.0.1/32 md5
host all all 192.168.0.25/24 md5
# IPv6 local connections:
host all all ::1/128 md5
# Allow replication connections from localhost, by a user with the
# replication privilege.
local replication all peer
host replication all 127.0.0.1/32 md5
host replication all ::1/128 md5
problem was in postgresql.conf. "md5" was OK. Did not need "trust" in pg_hba.conf.
I had...
listen_addresses = '::'
Now have...
listen_addresses = 'localhost'
All ok now. Thanks.
Thank you for following up to let the Community know the resolution.
we use Azure postgres paas service , it seemed they can't change the settings for us. we don't want to change the database, any other workaround ?
Hi Mike,
My theory is the authentication method has to be trust instead of md5. There are sample pg_hba.conf file entries in this article: Confluence PostgreSQL JDBC direct connection refused
I look forward to hearing whether the setup wizard can be completed with the PostgreSQL configuration recommended in the article.
Ann
