problem with confluence html macro
Dawid Janocha October 13, 2017
Hello i got a problem , i  am  using confluence 3.5.7 , and i want to get dynamic link display of Embedded  tweets timeline ,  as i use confluence html macro  at Adaptavist Theme "THEME BUILDER "  , i get embedded link from twitter and the result is. The Iframe start up after 2 seconds the timeline disappears and  iframe stopped working and get error  Plugin upgrade needed (also tried this macro at confluence  standard theme But still the same problem ) . So my question is What to do  without upgrading the Plugin
Shannon S
October 13, 2017
Hi Dawid,
Are you using this add-on: ThemeBuilder for Confluence?
If so, it's only compatible with Confluence versions 5.9.8 - 6.4.2. You'll want to upgrade Confluence first to 5.0.3, and then to at least 5.9.8.
You can obtain the download files necessary from the Confluence Server Download archives.
Let us know if you have any questions.
Kind Regards,
Shannon
Dawid Janocha October 26, 2017
Sorry for my delay , the problem get resolved as well  , thanks  a lot for fast respond
Kind Regards
Dawid
Shannon S
October 26, 2017
No worries, Dawid! Happy we were able to assist.
Kind Regards,
Shannon
Dawid Janocha November 2, 2017
Cheers for fast respond and assist,   Shannon
kind regards ,
Dawid
Nic Brough -Adaptavist-
October 13, 2017
Themebuilder is only really supported on supported version of Confluence, so you should upgrade to one of those.
However, yes, Themebuilder has been around for a very long time, and yes, there are versions for Confluence 3, so I assume you're using a valid one of those.
However, from memory, there is a bug in that version of Themebuilder which means iframes will not work.  There is no "fix" for it other than upgrading.
Ok , Cheers Nic :D ,  sorry for delay , i already make the choice and it get resolved.
best regards ,
Dawid
atlassian, confluence, marketing templates, confluence templates, marketing project management, content strategy, campaign planning, marketing collaboration, confluence for marketers, atlassian learning, marketing workflows, confluence best practices
5 must-use templates for Marketing teams (from a Confluence Marketer!) 👩🏻‍🎨
Read more 📚
