Hello
Team im configured server remotely
I installed confluence and postgres , when i try to connect my database to postgres , for the simple way , when i hit test connection : it looks succeded as picture describe below :
But when i hit next to finish the configuration , it takes a while and i get this error :
psql: FATAL: authentification Ident échouée pour l'utilisateur « postgres »
By connection string , the test failed :
I see that i have to change the pg_hba.conf and i did it : Here i my file :
# TYPE DATABASE USER ADDRESS METHOD
# "local" is for Unix domain socket connections only
local all all peer
# IPv4 local connections:
host all all 127.0.0.1/32 ident
host all all 0.0.0.0/0 md5
# IPv6 local connections:
host all all ::1/128 ident
# Allow replication connections from localhost, by a user with the
# replication privilege.
#local replication postgres peer
#host replication postgres 127.0.0.1/32 ident
#host replication postgres ::1/128 ident
host all all ::/0 md5
Note : im configured my server remotly .
Please i need your help .
Thank you very much for your response .
Regards
Karim
You can try the resolution on below guide it is for Jira but Confluence can have the same issue:
Hello @Brant Schroeder
Thank you for your reply
I didi it , i make trust rather than md5
====> host confluencedb confluenceadmin 0.0.0.0/0 trust
But after the test succes it's charge and return this error always :
Note : i cleaned the cache but always same problems.
I need your help please
Thank you
Do you have a software firewall on the box?
What is the Operating System of the server it is running on?
it's centos 7 , it's a vps .
But i wanna tell you that i open the port of confluence 8090 and the port of postgres , 5432 to acces from remotely from my pc , because the server doesnt have a graphic .
THank you
Regards
Have you tried turning off the firewall or looking at the firewall logs?
Is Confluence a stand alone instance or are you using Jira for authentication?
right now the problem with the user is solved , but when the test succed in two ways , it take a while and tell me
vps796322.ovh.net n'autorise pas la connexion.
Voici quelques conseils :
ERR_CONNECTION_REFUSED
Regards
