quick search - searching the body of the article
Tomaž K. July 1, 2014
Can confluence be configured that quick search would also searches the document body not just the title.
For example:
Confluence holds a document with Title: Title 1 and with body: Document body 1
If I enter "body" into the quick search field no result is shown, but if I press ENTER the result page shows me the right document.
I would like that quick search searches exactly the same way as a "normal" search.
Wayne Wong
July 17, 2014
Hi Tomaz,
There is another similar post here https://answers.atlassian.com/questions/94158/search-and-edit-bodycontentthat you can refer to.
Good luck :)
Wayne Wong
Register now
