setMacroJsOverride for macro with no parameters
robert_egan_305 July 23, 2020
I have a macro with no parameters. All the content is in the body.
In the past I have called setMacroJsOverride to define an 'opener' callback. I still want to do that with this macro, except it seems the editor does not call the opener when the macro has no parameters.
What callback should I define instead of 'opener'?
Bill Bailey
July 23, 2020
What if you add a dummy parameter to your macro? Does it work then?
robert_egan_305 July 24, 2020
Yes. I decided to add a parameter called "description" and make it required. Which was probably a good idea anyway, considering how poorly developers document their content :)
Yusuf TAMBAG September 14, 2020
Just put empty parameter tag like <parameters/> inside macro definition, parameter is not required but parameters tag is.
SERVER
