show mindmaps (.mm, .mmap, .mmp etc) in confluence
red sonja
is there any possibility to see attached mindmaps - eg mindmanager files?
these are files ending with *.mmap or *.mmp
I'm searching for something like the 'show ppt' or xls plugin..
we do project management via confluence and are using mindmaps quite often and therefore really would need this feature.
William Zanchet [Atlassian]
November 3, 2013
Hi Red,
We don't have such macro that would be able to see such files. However I created a feature request in Confluence to support Mindmaps as you can see here:
https://jira.atlassian.com/browse/CONF-31465
I would strongly suggest that you vote on this issue to increase its popularity and add it to your watchlist for future updates.
I hope this helps.
WZ
Mary Far
January 7, 2021
Hey Guys, we also need this feature in order to integrate the mindmap diagrams with confluence and make them accessible to other coworkers.
Thanks and regards
Like • David Hutcheson likes this
David Hutcheson
June 28, 2021
I would like this too
jfuentes September 4, 2020
.  We use MM and it would be wonderful to integrate them  .  I can stop the PDFs and they would always have an updated view
red sonja
ok thank you!
