I am trying to create a document with two columns: the first one being code and the second being a description of that code.
The basic setup is this:
{section}
{column:width=50%}
{panel}
h1. Code column
{code}
// code goes here
{code}
{panel}
{column}
{column:width=50%}
{panel}
h1. Explanation column
_something useful goes here_
{panel}
{column}
{section}
The problem is that if the text in the {code} section is wider than the column, it will cause the column to take up size accordingly instead of keeping the block at 50%.
Has anyone else run into this issue and/or does anyone have a workaround?
The problem is that by default, table cells expand to the size of their contents.
This kind of thing should do the trick:
<style> table.sectionMacro { table-layout: fixed; } </style>
Help us plant more trees
