没有管理界面
hnyztcl
March 11, 2020
我今天把jira,bitbucket,confluence,crowd升级到最新版后,其余配置都正常(包括sso登录),唯独Crowd的管理界面没了,我已经使用管理员账户登录crowd,但是没看到管理功能,只有修改密码等基本个人信息管理功能。
Rick Li
April 22, 2020
Hi hnyztcl,
Welcome to the community.
Have you solved your problem?
If not, here is the possible solution for your issue.
https://confluence.atlassian.com/confkb/member-of-crowd-administrators-group-is-unable-to-see-administration-menu-732531902.html
You can do a diagnostic. if your issue is the same, then follow the Resolution in the above page .
