Is anybody can help me?
Downloaded the crowd atlassian-crowd-2.7.0-war.zip OK
Extract the zip file and deployed on glassfish server:OK
start up the crowd Setup WizardOK
get an error at the finally setup : see below
com.atlassian.crowd.exception.ApplicationNotFoundException: Application <crowd> does not exist
If the both selected False: get HTTP Error 404
and then every time I try to open http://localhost:8080/crowd, get same problem.
Have no idea how to fix this problem. This trouble me a long time, Anybody can help me? Thanks
Sounds like something didn't go as planned in the setup process, but it's hard to tell what's wrong from so little information.
I suggest you open a support request so our friendly support team can help you troubleshoot and get you going.
I fixed this problem by modify the database collate to utf8_bin, And now I can complete the setup wizard, But I can not login as previous setting default username and password
The login box keep pop up everytime when I filled and tryed to login, Is there any problem?
What Tomcat and JDK versions are you using?
