CSV importer in Crowd
Ron Jacob
I am trying to import users using CSV importer in Crowd
It always give error "The file "C:\Users\XXX\example_users_file.csv" cannot be found or read."
Location is correct and in right format .csv
Marcin Kempa
March 22, 2018
Hi @Ron Jacob.
If the location of the file is correct, please check the permissions on that file and please make sure that the user the Crowd server is running has read access to that file.
Best Regards,
Marcin Kempa
Aswin P K June 29, 2022
I am also facing the same issue. Please let me know if you know the solution.
Thank you
