I would like to know if it is possible to connect Crowd Server to Jira or Confluence Data Center. I did some searching myself but the only thing I found is that connecting Crowd Data Center with Jira Server is a supported setup.
Thank you in advance
Till
Hi @Till Hannemann ,
Yes, It is possible to connect Crowd Server to Jira Data Center or Confluence Data Center for user management.
Here's are some kb articles by using that you can set up the connection:
By following steps mention in above documents, you can connect Crowd Server to Jira Data Center or Confluence Data Center for user management.
Also, if you feel my input help you please accept the answer.
Bhushan
Hello Bhushan,
thank you very much for your fast answer.
Best regards
Till
