Can't log in to Crowd using Chrome, but can using Safari.
dustingooding
My main, preferred browser is Chrome. Unfortunately, I can't log in to Crowd using it. When I get to the login screen at http://server.name/crowd/console/login.action, I go through the log in motions you'd expect (user, pass, Log in >>)... but the screen just refreshes back to an empty login screen. No errors, just back to square one.
When I do the same with Safari, I log in without any trouble.
Brendan Patterson
June 7, 2012
I get around this problem by using a Chrome "incognito" window. But I don't yet know the reason either. In Chrome Shift+CTRL + N
Also happens with Confluence sometimes.
dustingooding
That seems to work, but is obviously just a workaround. I wonder what the actual right solution is?
Andrei [errno]
February 3, 2012
  • same here - Chrome 16.0.9
  • I wrote it off for some combination of cookies/sessions. after cleaning up all my chrome data it works again.
charleslcso
Yes, I have the same problem with Chrome 17.
