Connection timeout linking Jira and Crowd
Tom Lister
June 4, 2020 edited
We are getting a timeout message adding a Crowd directory to our Jira Server.
Application is defined in Crowd.
Addin config in Jira returns:
Connection test failed. Response from the server:
org.apache.http.conn.ConnectTimeoutException: Connect to crowd.cheileu.com:80 [crowd.cheileu.com/54.194.1.186, crowd.cheileu.com/54.194.94.24] failed: connect timed out
The Jira logs only show the timeout error
Caused by: org.apache.http.conn.ConnectTimeoutException: Connect to crowd.cheileu.com:80 [crowd.cheileu.com/54.194.1.186, crowd.cheileu.com/54.194.94.24] failed: connect timed out
I've RTFM'd a few times and I think we've done everything
Postman returns the crowd web-page
Curl doesn't seem to return anything
I have not managed to get a response to a crowd REST call
Any suggestions?
Tom
Dave Theodore [Coyote Creek Consulting]
Is Crowd listening on port 80? By default, it listens on 8095.
Tom Lister
Hi @Dave Theodore [Coyote Creek Consulting]
The problem turned out to be security issues between Crowd and Jira nodes in AWS.
We could call it from other devices
getting a Curl command to work on server showed the way
Tom
