Crowd AdoptOpenJDK
Ti.Sch. February 27, 2019
Oracle Java JDK and OpenJDK are listed on the Supported Platforms page.
Does OpenJDK refer to https://openjdk.java.net ?
Is AdoptOpenJDK also supported?
kind regards
Marty
February 27, 2019
Hi Timotheus,
I'm not on the Crowd team but I will try to help.
According to the support platforms page OpenJDK 1.8 is the currently supported version in 3.3.x https://confluence.atlassian.com/crowd/supported-platforms-191851.html
If having support in Crowd for another JDK version is important to you, I'd recommend creating an issue in our public issue tracker for Crowd: https://jira.atlassian.com/projects/CWD/issues
I hope that helps!
Ryan_Morgan
May 3, 2019
I have seen Jira and Confluence being supported for AdoptOpenJDK. Will we see support for crowd anytime soon?
Yoga Reddy {Appfire}
February 27, 2019
Hi @Ti.Sch.
Yes, AdoptOpenJDK 11 is a supported Java Version as mentioned here
You can test with the AdoptOpenJDK 11 in the test environment before deploying in the production.
Crowd 3.3.0+ supports JDK 8 only?
Like Marty likes this
