I'm not able to enable an installed plugin 2FA for Crowd: U2F & TOTP
Greg Lev June 29, 2022
CROWD 5.0, 2 nodes (cluster).
I have installed 2FA for Crowd: U2F & TOTP but cannot enable it with "This app failed to enable. Refer to the logs for more information."
The log extraction is as follows:
2022-06-30 02:05:07,665 http-nio-8095-exec-17 url: /crowd/plugins/servlet/upm; user: ge.lev INFO [atlassian.marketplace.client.MarketplaceClient] GET https://marketplace.atlassian.com/rest/2/
2022-06-30 02:05:08,442 http-nio-8095-exec-18 url: /crowd/rest/plugins/1.0/com.alphaserve.crowd-authplugin-key; user: ge.lev INFO [atlassian.plugin.manager.PluginEnabler] Resolving 1 plugins
2022-06-30 02:05:08,443 http-nio-8095-exec-18 url: /crowd/rest/plugins/1.0/com.alphaserve.crowd-authplugin-key; user: ge.lev INFO [atlassian.plugin.manager.PluginEnabler] Enabling 1 plugins: [com.alphaserve.crowd-authplugin]
2022-06-30 02:05:08,444 http-nio-8095-exec-18 url: /crowd/rest/plugins/1.0/com.alphaserve.crowd-authplugin-key; user: ge.lev INFO [blueprint.extender.support.DefaultOsgiApplicationContextCreator] Discovered configurations {osgibundle:/META-INF/spring/*.xml} in bundle [2FA for Crowd: U2F & TOTP (com.alphaserve.crowd-authplugin)]
2022-06-30 02:05:08,452 FelixDispatchQueue INFO [osgi.container.felix.FelixOsgiContainerManager] Started bundle com.alphaserve.crowd-authplugin (61)
2022-06-30 02:05:08,453 http-nio-8095-exec-18 url: /crowd/rest/plugins/1.0/com.alphaserve.crowd-authplugin-key; user: ge.lev INFO [plugin.osgi.factory.UnrecognizedModuleDescriptorServiceTrackerCustomizer] Turned unrecognized plugin module com.alphaserve.crowd-authplugin:rest into module com.alphaserve.crowd-authplugin:rest (Rest resources)//rest//authpluginresources/1.0
2022-06-30 02:05:08,453 http-nio-8095-exec-18 url: /crowd/rest/plugins/1.0/com.alphaserve.crowd-authplugin-key; user: ge.lev INFO [atlassian.plugin.manager.PluginEnabler] Waiting for 1 plugins to finish ENABLING: [com.alphaserve.crowd-authplugin]
2022-06-30 02:05:08,453 http-nio-8095-exec-18 url: /crowd/rest/plugins/1.0/com.alphaserve.crowd-authplugin-key; user: ge.lev INFO [atlassian.plugin.util.WaitUntil] Plugins that have yet to be enabled: (1): [com.alphaserve.crowd-authplugin], 300 seconds remaining
2022-06-30 02:05:08,529 ThreadPoolAsyncTaskExecutor::Thread 44 INFO [internal.dependencies.startup.DependencyWaiterApplicationContextExecutor] No outstanding OSGi service dependencies, completing initialization for NonValidatingOsgiBundleXmlApplicationContext(bundle=com.alphaserve.crowd-authplugin, config=osgibundle:/META-INF/spring/*.xml)
2022-06-30 02:05:08,714 ThreadPoolAsyncTaskExecutor::Thread 45 ERROR [plugin.osgi.factory.OsgiPlugin] Unable to start the plugin container for plugin 'com.alphaserve.crowd-authplugin'
org.springframework.beans.factory.UnsatisfiedDependencyException: Error creating bean with name 'directorySearchServiceImpl': Unsatisfied dependency expressed through constructor parameter 0; nested exception is org.springframework.beans.factory.NoSuchBeanDefinitionException: No qualifying bean of type 'com.atlassian.crowd.manager.directory.DirectoryManager' available: expected at least 1 bean which qualifies as autowire candidate. Dependency annotations: {}
at org.springframework.beans.factory.support.ConstructorResolver.createArgumentArray(ConstructorResolver.java:800)
at org.springframework.beans.factory.support.ConstructorResolver.autowireConstructor(ConstructorResolver.java:229)
at org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.autowireConstructor(AbstractAutowireCapableBeanFactory.java:1372)
at org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.createBeanInstance(AbstractAutowireCapableBeanFactory.java:1222)
at org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.doCreateBean(AbstractAutowireCapableBeanFactory.java:582)
at org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.createBean(AbstractAutowireCapableBeanFactory.java:542)
at org.springframework.beans.factory.support.AbstractBeanFactory.lambda$doGetBean$0(AbstractBeanFactory.java:335)
at org.springframework.beans.factory.support.DefaultSingletonBeanRegistry.getSingleton(DefaultSingletonBeanRegistry.java:234)
at org.springframework.beans.factory.support.AbstractBeanFactory.doGetBean(AbstractBeanFactory.java:333)
at org.springframework.beans.factory.support.AbstractBeanFactory.getBean(AbstractBeanFactory.java:208)
at org.springframework.beans.factory.support.DefaultListableBeanFactory.preInstantiateSingletons(DefaultListableBeanFactory.java:953)
at org.springframework.context.support.AbstractApplicationContext.finishBeanFactoryInitialization(AbstractApplicationContext.java:918)
at org.eclipse.gemini.blueprint.context.support.AbstractDelegatedExecutionApplicationContext.access$1600(AbstractDelegatedExecutionApplicationContext.java:57)
at org.eclipse.gemini.blueprint.context.support.AbstractDelegatedExecutionApplicationContext$4.run(AbstractDelegatedExecutionApplicationContext.java:322)
at org.eclipse.gemini.blueprint.util.internal.PrivilegedUtils.executeWithCustomTCCL(PrivilegedUtils.java:85)
at org.eclipse.gemini.blueprint.context.support.AbstractDelegatedExecutionApplicationContext.completeRefresh(AbstractDelegatedExecutionApplicationContext.java:287)
at org.eclipse.gemini.blueprint.extender.internal.dependencies.startup.DependencyWaiterApplicationContextExecutor$CompleteRefreshTask.run(DependencyWaiterApplicationContextExecutor.java:137)
at java.base/java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1128)
at java.base/java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:628)
at java.base/java.lang.Thread.run(Thread.java:834)
Caused by: org.springframework.beans.factory.NoSuchBeanDefinitionException: No qualifying bean of type 'com.atlassian.crowd.manager.directory.DirectoryManager' available: expected at least 1 bean which qualifies as autowire candidate. Dependency annotations: {}
at org.springframework.beans.factory.support.DefaultListableBeanFactory.raiseNoMatchingBeanFound(DefaultListableBeanFactory.java:1799)
at org.springframework.beans.factory.support.DefaultListableBeanFactory.doResolveDependency(DefaultListableBeanFactory.java:1355)
at org.springframework.beans.factory.support.DefaultListableBeanFactory.resolveDependency(DefaultListableBeanFactory.java:1309)
at org.springframework.beans.factory.support.ConstructorResolver.resolveAutowiredArgument(ConstructorResolver.java:887)
at org.springframework.beans.factory.support.ConstructorResolver.createArgumentArray(ConstructorResolver.java:791)
... 19 more
2022-06-30 02:05:08,717 ThreadPoolAsyncTaskExecutor::Thread 45 INFO [extender.internal.support.ExtenderConfiguration] Application context succesfully closed (NonValidatingOsgiBundleXmlApplicationContext(bundle=com.alphaserve.crowd-authplugin, config=osgibundle:/META-INF/spring/*.xml))
2022-06-30 02:05:08,718 ThreadPoolAsyncTaskExecutor::Thread 45 ERROR [extender.internal.support.ExtenderConfiguration] Application context refresh failed (NonValidatingOsgiBundleXmlApplicationContext(bundle=com.alphaserve.crowd-authplugin, config=osgibundle:/META-INF/spring/*.xml))
... 19 more
2022-06-30 02:05:08,718 FelixDispatchQueue INFO [osgi.container.felix.FelixOsgiContainerManager] Stopped bundle com.alphaserve.crowd-authplugin (61)
2022-06-30 02:05:08,718 ThreadPoolAsyncTaskExecutor::Thread 45 ERROR [internal.dependencies.startup.DependencyWaiterApplicationContextExecutor] Unable to create application context for [com.alphaserve.crowd-authplugin], unsatisfied dependencies: none
... 19 more
2022-06-30 02:05:09,454 http-nio-8095-exec-18 url: /crowd/rest/plugins/1.0/com.alphaserve.crowd-authplugin-key; user: ge.lev INFO [atlassian.plugin.manager.PluginEnabler] Plugin 'com.alphaserve.crowd-authplugin' is now DISABLED
2022-06-30 02:05:09,501 http-nio-8095-exec-18 url: /crowd/rest/plugins/1.0/com.alphaserve.crowd-authplugin-key; user: ge.lev INFO [upm.core.log.PluginSettingsAuditLogService] Thu Jun 30 02:05:09 MSK 2022 ge.lev: Failed to enable app 2FA for Crowd: U2F & TOTP (com.alphaserve.crowd-authplugin)
2022-06-30 02:06:15,955 http-nio-8095-exec-34 url: /crowd/console/secure/saml/sso.action; user: as.ilnykh INFO [xmlsec.signature.support.SignatureSupport] No KeyInfoGenerator was supplied in parameters or resolveable for credential type org.opensaml.security.x509.X509Credential, No KeyInfo will be generated for Signature
What's wrong?
SERVER
VERSION
5.0.0
