Hi, I was trying to integrate crowd with SSL. I followed all the steps in https://confluence.atlassian.com/display/CROWD/Configuring+Crowd+to+Work+with+SSLand i still cannot get it working. I have verified that certificate has got imported successfully. However when i start crowd, i get these errors
INFO: Deploying configuration descriptor C:\CROWD_INSTALL\apache-tomcat\conf\Catalina\localhost\openidclient.xml
Jul 21, 2014 6:30:49 AM org.apache.catalina.core.StandardContext startInternal
SEVERE: Error listenerStart
SEVERE: Context [/openidclient] startup failed due to previous errors
Jul 21, 2014 6:30:49 AM org.apache.catalina.startup.HostConfig deployDescriptor
INFO: Deploying configuration descriptor C:\CROWD_INSTALL\apache-tomcat\conf\Catalina\localhost\openidserver.xml
Jul 21, 2014 6:31:01 AM org.apache.catalina.core.StandardContext startInternal
SEVERE: Context [/openidserver] startup failed due to previous errors
Jul 21, 2014 6:31:02 AM org.apache.catalina.loader.WebappClassLoader clearReferencesThreads
SEVERE: The web application [/openidserver] appears to have started a thread named [HSQLDB Timer @556ef89c] but has failed to stop it. This is very likely to create a memory leak.
Jul 21, 2014 6:31:02 AM org.apache.catalina.startup.HostConfig deployDirectory
INFO: Deploying web application directory C:\CROWD_INSTALL\apache-tomcat\webapps\ROOT
Jul 21, 2014 6:31:02 AM org.apache.coyote.AbstractProtocol start
INFO: Starting ProtocolHandler ["http-bio-8095"]
INFO: Starting ProtocolHandler ["http-bio-8443"]
Jul 21, 2014 6:31:02 AM org.apache.catalina.startup.Catalina start
INFO: Server startup in 88428 ms
Jul 21, 2014 6:31:34 AM org.apache.tomcat.util.http.Cookies processCookieHeader
INFO: Cookies: Invalid cookie. Value not a token or quoted value
Note: further occurrences of Cookie errors will be logged at DEBUG level.
And when i try to access the link of crowd using https, i see the following error.
Exception in thread "http-bio-8443-exec-3"
Exception: java.lang.OutOfMemoryError thrown from the UncaughtExceptionHandler i
Exception in thread "http-bio-8443-exec-4"
Exception in thread "http-bio-8443-exec-7" Exception in thread "http-bio-8443-ex
ec-9"
n thread "http-bio-8443-exec-9"
Exception in thread "C3P0PooledConnectionPoolManager[identityToken->31j0v293ok3k
nl1rcwmlj|15b4634]-AdminTaskTimer" Exception in thread "http-bio-8443-exec-10" E
xception in thread "http-bio-8443-exec-8" Exception in thread "http-bio-8443-exe
c-6"
n thread "C3P0PooledConnectionPoolManager[identityToken->31j0v293ok3knl1rcwmlj|1
Am not sure how to fix this issue. Any clues?
Make sure you have java_opts that point to the keystore and truststore:
JAVA_OPTS="-Xms128m -Xmx1024m -XX:MaxPermSize=256m $JAVA_OPTS -Djavax.net.ssl.keyStore=/<pathtokeystore>/.keystore -Djavax.net.ssl.keyStorePassword=changeit -Djavax.net.ssl.trustStore=/<pathtokeystore>/.keystore -Djavax.net.ssl.trustStorePassword=changeit"
I would be very surprised if you need that much memory to run crowd, especially if this is a new install. Your permsize shouldn't need to be more than 256m and at the most 512m. For the Heap I would be suprised if you need more than 1024m max.
In addition the default JDK keys store is not pkcs12 but, JKS. You might need to convert your cert to a x509 and then import it and the private key to your keystore or make sure you set the keystore type to pkcs12.
Hi Shravanthi, I see some OutOfMemoryError erros in your logs, you may want to increase Crowd memory and see if it brings any improvement.
Cheers
I have increased the memory setting. Here is my setenv.bat file in Crowd-Install/apache-tomcat/bin/setenv.bat contents
JAVA_OPTS="-Xms3072m -Xmx6144m -XX:PermSize=3072m -XX:MaxPermSize=3072m"
It is still giving me the same error. Should i increase it further? My crowd server is Windows 2008 server with 8GB RAM. Please let me know how if i need to increase it further.
I also see this in the log. What does it mean?
SEVERE: Failed to initialize end point associated with ProtocolHandler ["http-bi
o-8443"]
java.io.IOException: DerInputStream.getLength(): lengthTag=109, too big.
I verified if certificate was imported properly by running command
keytool -list -v -keystore "C:\Program Files\Java\jdk1.7.0_55\jre\lib\security\cacerts"
and it shows the certificate am looking for. Its in pkcs12 format.
I was able to get past out of memory exception after i removed openid xml so startup of crowd did not give any error and i can access the crowd login with https and 8443 port.
However when i try to login using admin credentials, it throws these errors (in crowd logs)
http-bio-8443-exec-4 ERROR [xfire.transport.http.HttpChannel] java.net.SocketException: java.security.NoSuchAlgorithmException: Error constructing implementation (algorithm: Default, provider: SunJSSE, class: sun.security.ssl.SSLContextImpl$DefaultSSLContext)
Line 9885: 2014-07-22 02:14:59,747 http-bio-8443-exec-4 ERROR [xfire.transport.http.HttpChannel] java.net.SocketException: java.security.NoSuchAlgorithmException: Error constructing implementation (algorithm: Default, provider: SunJSSE, class: sun.security.ssl.SSLContextImpl$DefaultSSLContext)
Line 9886: 2014-07-22 02:14:59,750 http-bio-8443-exec-4 ERROR [crowd.integration.springsecurity.CrowdSSOAuthenticationProcessingFilter] Unable to unset Crowd SSO token
Line 10028: 2014-07-22 02:15:00,010 http-bio-8443-exec-5 ERROR [crowd.console.action.Login] Failed to connect to the authentication server, please check your crowd.properties
Also saw these in logs
Caused by: org.codehaus.xfire.XFireException: Couldn't send message.
Caused by: java.net.SocketException: java.security.NoSuchAlgorithmException: Error constructing implementation (algorithm: Default, provider: SunJSSE, class: sun.security.ssl.SSLContextImpl$DefaultSSLContext)
Caused by: java.security.NoSuchAlgorithmException: Error constructing implementation (algorithm: Default, provider: SunJSSE, class: sun.security.ssl.SSLContextImpl$DefaultSSLContext)
Caused by: java.io.IOException: DerInputStream.getLength(): lengthTag=109, too big.
Am using a pkcs12 keystore and it is imported properly. I tried to give keystoretype as PKCS12(modified java.security file as well to pkcs12) but even login screen did not come up. So reverted the changes
