Hey DC Community!
I am Mike from the DC product group. I am excited to announce that app monitoring is now available for Jira 9.1!
Benefits of using App monitoring
Some of you may recognise this feature from its release in Confluence 7.18. App monitoring enables your organisation to gain greater insight into third-party apps' resource utilisation and performance via performance and API usage metrics.
It gives you a deeper insight into what apps are doing in your instances. For example, it helps to troubleshoot issues with a specific app or to help you determine whether or not an app may have contributed to a drop in overall performance or stability.
In addition, this feature provides guidance and templates to connect your instance with Prometheus and Grafana so that you can quickly set up App monitoring dashboards, as the sample image shows below.
Start to monitor Apps and gain performance insights
Please visit our feature document and learn more about App Monitoring in Jira 9.1. And check out our guide, which helps you monitor Jira with Prometheus and Grafana. It is also highly recommended to look at the App performance metrics.
Again, thank you all for being part of the DC community and sharing your passion for improving our products. Please do give us your feedback and leave your comments below.
DC Product Team
Xiaoxiang _Mike_ Ni
4 comments
