How to customize jira-config.properties on docker deployment
Marcelo Mella
I'm trying to deploy Jira DC on dockers, and i can't find a way to configure jira-config.properties.
Some of the configurations i use at this moment are these:
jira.lf.date.relativize = false
jira.export.excel.enabled = true
jira.index.issue.threads = 40
upgrade.reindex.allowed=false
2 comments
Dylan Rathbone
March 28, 2022
Hi @Marcelo Mella
One option of doing this is by mounting jira.properties as a volume. Check out this article on how this can be done:
https://confluence.atlassian.com/jirakb/how-to-customize-files-inside-a-jira-docker-container-1026533922.html
Dylan.
Like • Pamela Strucker likes this
Marcelo Mella
i thought that you can only mount directories.
It seems that this should work fine
Sebastian Schmidt
Hey @Marcelo Mella you can do both, Docker Volume is a complex topic. You can read up on that here https://docs.docker.com/engine/reference/run/#volume-shared-filesystems and here https://docs.docker.com/storage/volumes/
Marcelo Mella
Thanks @Sebastian Schmidt , to add one more complexity, i'm using AWS Fargate.
I can't mount a single file from a EFS, so i'm raising a support ticket on AWS to ask for some help
Like • Sebastian Schmidt likes this
Marcelo Mella
For any of those that are trying to configure jira-config.properties on a Fargate configuration, the best answer is to use a "sidecar".
See the next link:
https://kichik.com/2020/09/10/mounting-configuration-files-in-fargate/
Like • Thiago Masutti likes this
atlassian, opsgenie migration, jira service management, incident response, on‑call management, alerting tools, migration guide, devops operations, service reliability, atlassian learning, migration best practices, opsgenie support, IT operations
Join the Opsgenie Migration group 🚚
Heads up! Opsgenie's features are moving to Jira Service Management and Compass. Planning your migration? Join our dedicated group for resources and tips from Atlassian and the Community to ensure a smooth transition.
Check it out ↗
