Insight IQL Syntax Help to obtain Object History Data
Crystal Rouse
I am trying to create an IQL syntax to use in filters and reports showing when an Insight Objects data has changed.  Other than using the API, I can't find information on using IQL to reference the Objects Activity History Data.
For example, I need to create a report for when a field/attribute changes using IQL.
3 comments
David Sumlin
June 23, 2021
Only other thing I can think of is to use SQL against the database directly. It's not completely straight forward, but it's possible.
Crystal Rouse
Thanks for the reply but unfortunately I do not have direct access to the database.
Like • software likes this
Marina Veselić
It would be a cool functionality to have an IQL option to determine which objects are subjected to automation BEFORE the event and an IQL to determine if the rule should apply AFTER the event. :D
Alan Bruce
Hello Crystal,
Were you able to get this to work? I have the exact same need.
