Proactive monitoring of atlassian tool
Hitendra Chauhan
Is someone manage to create custom developed proactive monitoring of atlassian tools ?
4 comments
Sebastian Kleinholz
January 22, 2018
Craig Castle-Mead
February 19, 2018
Hey Hitendra,
Proactive monitoring could mean a number of things, so depends on exactly what you're looking to solve. Our arsenal includes:
  • NewRelic
    • Infrastructure (monitors the ram/disc/cpu etc)
    • APM (deeper insights into the JVM itself)
    • Synthetics (basic HTTP checks from a number of locations to check the service is alive
  •  AWS
    • Covers some of the same bases as NewRelic, but we also leverage CloudWatch as it gives us added insights into some of the AWS specifics (RDS read/write throughput Vs thresholds, ELB queues etc)
  • ELK (https://www.elastic.co/elk-stack)
    • Get the nginx proxy logs + application logs and send them to a central elasticsearch database, use Kibana to visualize things like application warns/errors over time, usage by username
Finding correlations between the various tools can help - but you can also get lost in too much data. May be simpler to find an API endpoint you can call, time how long it takes to respond and if it takes longer than your threshold, or, doesn't return the expected data then you likely have an issue. This follows the pattern of monitoring the application itself, and not the servers as your users use the application, not the servers (directly).
CCM
Prerak Y Diwan
Hi Craig,
Hope you are doing well.
For ELK (https://www.elastic.co/elk-stack)
Can you point me to a tutorial on how to accomplish this using ELK stack?
I found video "https://www.youtube.com/watch?v=SQ2pyS6aTpM"
mentioning about the similar topic but did not show the audience how to actually set it up.
Prerak
Pedro Felgueiras
February 20, 2018
This is a verry intressing topic and you got a verry intressing presentation here https://pt.slideshare.net/aca_it/monitor-your-atlassian-stack-like-the-nsa
Curently we are using the Google Analytics, JavaMelody and Nagios. We had tried the ELK stack but the logstash was dificult to configure with catalina.out
I think atlassian should provide some guidelines on this topic.
Sebastian Kleinholz
February 20, 2018
This discussion is related to this topic.
Like • Hasna likes this
