I want to deploy Bitbucket on a context path like "/bitbucket".
I'm setting `service.contextPath=/bitbucket`. It updates `SERVER_CONTEXT_PATH` in YAML (which is great), but the readiness probe is still at "/status". As a result it's never "ready". I suspect the tests may have the same issue.
To get this to work in my setup, right now I'm using the following patch.
kubectl patch statefulset bitbucket --type='json' \
-p='[{"op": "replace", "path": "/spec/template/spec/containers/0/readinessProbe/httpGet/path", "value": "/bitbucket/status"}]'
kubectl delete pod bitbucket-0
It looks like it could be a bug in the chart.
@Konrad Garus can you please file an issue at https://github.com/atlassian/data-center-helm-charts?
I'd be happy to do it, but I don't know how.
It clearly says that Github issues is for feature requests only: https://github.com/atlassian/data-center-helm-charts/issues/new/choose
The main support form is for Atlassian products, it wants a product license (which is irrelevant here).
I created a ticket there just in case, we'll see if that works: https://getsupport.atlassian.com/servicedesk/customer/portal/35/CA-1683371
@Yevhen OK, that support ticket was a major failure. I don't have a product SEN and no-one will talk to me because my email is associated with a partner and I'm hitting the authorization wall.
Please let me know what exactly is the right path to submit bugs for these charts.
Hi @Konrad Garus , can you please raise a Github issue, or a PR if you have a solution already, with `bug` label? We'll take care of it from there. Cheers.
@Yifei Zhang Done: https://github.com/atlassian/data-center-helm-charts/issues/377
I can't see a way to add a label, though.
Thank you, @Konrad Garus ! We'll look into it.
