We have a recent deployment of the Atlassian Confluence helm charts on a single non-clustered pod. I am setting up backups but have noticed that the attachments are on the EBS volume? I am surprised that they are not on the EFS volume by default as I understood the EBS volume to be "throwaway".
root@confluence-0:/var/atlassian/application-data/confluence/attachments/ver003# df -h .
Filesystem Size Used Avail Use% Mounted on
/dev/nvme1n1 590G 899M 589G 1% /var/atlassian/application-data/confluence
What am I missing?
Solved! Go to Solution.
In the values.yaml, I see the following notes when provisioning the "local-home" volume:
# NOTE: Due to the ephemeral nature of pods this approach to provisioning volumes for
# pods is not recommended. Dynamic provisioning described above is the prescribed
# approach.
I have configured the local-home volume via the dynamic approach on an EBS volume per this comment.
So would you recommend moving to a single/multi node cluster setup then? Or using the non-recommended customVolume approach?
This is to emphasize that leaving it as emptyDir: {} will result in data loss. You can definitely use a custom volume for local home if you run in a non clustered mode.
