🔌 Plug into Jira: Execute tests and improve quality right within Jira Software
Previously on the Plug into Jira series, we’ve covered how the Release Hub in Jira Software can be the single source of truth for software teams when deploying releases. This week, we're moving onto another part of the SDLC and sharing how software teams can deliver quality code by integrating testing solutions such as Xray and Zephyr to execute tests right within Jira Software.
Why testing and QA are essential to agile software development
Testing in an agile software development environment is an essential part of delivering a good experience for the end user while maintaining velocity. By integrating QA tracking, testing, and analysis into each phase of the agile software development process, teams can move faster, identify blockers with more accuracy, and release updates more effectively.
Test management tools enable all team members to participate in quality-related tasks, removing the friction that exists whenever different team roles use siloed tools. Bringing testing capabilities within Jira Software helps tightly integrate product management, development, and testing to streamline efficiency and productivity. By providing the means to track your test coverage and the ability to see test results right within Jira Software, teams can better understand and improve the quality of their deliverable.
Use a test management tool with Jira Software so everyone on the team can be on the same page
We asked Xray and Zephyr, two of the top test management vendors in the Atlassian Marketplace, to share with us the top benefits of using their apps with Jira Software.
Test Management right from Jira with Xray
Use the Xray Test Management for Jira app to create tests and track test coverage right from Jira Software. Xray provides native test management and enables teams to manage tests as Jira issues, making it easier for teams to collaborate on quality testing in one centralized location.
Creating a ‘Test’ and managing it as a Jira issue can be easily done with a click. Teams can select the type of test to run, specify the steps and expected results, and easily verify the validity of the test scenario. Manage testing from end-to-end by tracking requirements and test cycles, and link requirements and test cases directly to Jira issues so everyone on the team has visibility of the context.
Xray provides a quick overview of the status of the Epic, making it easier to make release decisions based on the test status.
upbbTqVAs2qQKlW6xLGSShWLdfhVywHMEYXKcdr5agfkKsvfht3xsBd4NKBbwlJf8dOZ-0BnZiQGwveHX6sMx1Queb4lw1Ui1yexydLm12zXxn1v1PvKcOBsUGSsjW9v_B_5njVhoi76KV974PMWfmI.png
Use Xray to create and track test coverage in Jira Software
Use a ‘Test Plan’ to
define a testing scope and manage it as an issue in Jira Software to seamlessly integrate testing into project management workflows. Teams can include Test Plans in their sprint board to manage the test scope, track testing progress, and assign tests to team members. The Test Plan board consolidates progress for all the tests and teams can track each test execution history right within the Test Plan.
See consolidated test progress in the Xray Test Plan board view
Software teams often need to know if their product can be released or how their product is performing in a specific environment.
Xray’s Test Coverage Report helps answer these questions by providing a high-level overview of the testing deliverables.
Xray supports a variety of testing approaches and test automation frameworks. With the Test Coverage Report, teams can have a birds-eye view of the quality status of their deliverables, regardless of the type of testing that’s being conducted. Easily filter test results based on priority status or other criteria, and click on the chart to see the detailed test requirements for more context.
The Test Coverage information is updated in real-time and is multi-dimensional. Teams can easily analyze stories and requirements taking into account the latest test results, or just the test results obtained on a specific release or specific test environment.
Xray's Test Coverage Report provides an overview of the test status
Teams often need to diagnose where an error is coming from when a test fails. Xray’s Traceability Report provides an analysis of all the issues covered by the tests and helps trace the connections between issues and the resulting impact. This is especially useful for highly regulated industries that require traceability to comply with regulations. Xray helps software teams gain better visibility, traceability, and control during their testing process.
Use Xray's Traceability Report to uncover any errors found in the tests
Test Management right from Jira with Zephyr
Zephyr has two top test management tools in the Atlassian marketplace: Zephyr Scale and Zephyr Squad. Both help teams get end-to-end visibility of their test management, foster tighter collaboration, and enable faster releases. Zephyr Scale is a powerful solution with test planning, reporting, and reusability for teams across multiple projects. Zephyr Squad is perfect for small agile teams getting started with test management. In this blog post, we will use Zephyr Scale and the example to showcase how software teams can use Zephyr to improve visibility and collaboration during testing.
Zephyr Scale is scalable, performant test management inside Jira. It offers cross-project hierarchical test libraries, parameters, and test data—reducing redundancy and promoting reusability. Create and manage your test cases in the Zephyr Scale test case library, with over 70 cross-project reports, 60 gadgets, and 60 Confluence macros. Organize the test cases in folders, cloning, and exporting test cases in different formats (CSV, XML). Group the test cases by component, domain, or product, so teams can easily see all the tests in one place and customize the view they want to see to increase efficiencies.
Zephyr Scale enables end-to-end traceability within Jira, linking test cases to user stories and allowing single test execution from the issue screen. Use the Zephyr test player to record the execution of your test. You can assign statuses and set additional properties to this execution to record as much data as needed. Add attachments or raise issues such as defects found during testing in the format of Jira issues, so your dev team can easily plan and fix the defect in Jira.
The following screenshot is one example of the multiple reports we have available in Zephyr Scale. Teams can quickly get an overview of their testing by creating reports and filtering based on various criteria such as test cases and test cycles to assess the release readiness of your product.
Easily create test reports and filter based on various criteria in Zephyr Scale
Zephyr Scale also has a reusability feature named "call to test". This feature allows teams to reuse the current test case from another test case created in the past and easily customize new parameters. This is useful to keep your test case library consistent when you want to repeat some steps. Zephyr Scale simplifies testing at scale, driving alignment and empowering teams to deliver high-quality software.
Easily reuse repeatable test suites and customize parameters in Zephyr Scale
Jira Software as the consolidated single source-of-truth
Integrating test management tools like Xray and Zephyr with Jira Software can greatly improve software team's efficiency, collaboration, and overall testing process. By centralizing your test management activities, enhancing traceability, and providing powerful reporting and analytics, these integrations can help you maintain high-quality software development standards and ensure the success of your projects.
Explore the possibilities and benefits of integrating Xray and Zephyr with your Jira Software instance to streamline your test management processes and elevate your team's performance.
What are some of your experiences or pain points with test management? Let us know in the comments and happy testing!
23 comments
Sanjen Bariki
June 20, 2023
Thanks for Sharing this Information
Like 2 people like this
Arthur Coelho Pinto
Thanks for sharing!
Like Annie Lu likes this
Emily _ DevSamurai
This is very helpful. Thank you!
Jarosław Solecki _Deviniti_
It is helpful. The pain of those is usually the problem with requirements traceability. In my opinion the matrix works best here.
raj shaswat
Really helpful , thanks for sharing.
Alexander Pappert
June 26, 2023
does XRay only "translate" the status into some other words and create a page to show them?
Then I could also built my own dashoards and filter for the status.
Noushin Kananian
June 26, 2023
Thanks for sharing your invaluable knowledge and experience, it's really appreciated.
Shraddha Misri
Thanks for sharing, very informative. Thanks
Deepak_QMetry
Hi Guys,
you have a better option than Xray and Zephyr in features, UX, and price wise.  It is QMetry Test Management for Jira - https://marketplace.atlassian.com/apps/1215144/qmetry-test-management-for-jira-qtm4j?hosting=cloud&tab=overview.
Annie! This is unfair to other Marketplace App vendors like us that you are promoting these two specific apps.  We are also a platinum partner and do significant work with Atlassian.  I think you should add us as well to this article.
Lucas Modzelewski _Lumo_
Thanks for sharing.
I prefer Xray for Jira Cloud, they have great academy available, making it easy to understand basic concepts
Mohamed Benziane
Thank for this article !
Markus Fredén
July 4, 2023
Impressive post! 👍
Sakina
July 10, 2023
we have been using zephyr for more than 4 years now , it help us a lot
Ramakrishna _RK_
July 12, 2023
Nice Article!
Mary Agueros
July 12, 2023 edited
The information in the article and the various posts from Community members has been helpful on the topic of test tool integration with Jira. Regards Mary
@maurie.tarlac
Karen Bottai
Wow this was great!
Charlie Misonne
As a previous test engineer I'm sad I never had the chance to work with any of these tools. Instead we had spreadsheets or complex tools.
But process wise: I'm curious how teams plan their tests in a sprint. If a sprint takes 2 weeks and the testing teams needs multiple days to test. How do you do this assuming you want to release at the end of the sprint?
I've seen postponing testing to the next sprint but this is a bad practice if you ask me.
Benjamin Horst
August 10, 2023
Since we use a testing App in our On-Prem instance that is not available in the Cloud, this short overview was a great start. Thanks!
patricia
Thanks for sharing this information.
patricia
Thank you to share with us how to improve our deliveries.
Mark Rekveld - Marvelution
thanks for sharing
Roger Hughes
This is a really helpful summary, as it is something that our teams are currently attempting to work towards and have requested that JIRA assist in this QA task.
Piyush Annadate _ACE Pune_
Impressive details and post !
