Welcome to the Developer's Edge video series. This series examines Atlassian products and partner integrations through a developer’s lens, showing how an integrated toolchain can improve the developer experience while increasing productivity.
A better developer experience is a few steps away.
The next video in the Developer's Edge series shows how you can create a Forge app for Compass. You can use Atlassian’s Forge to remove friction from your development process and improve your developer experience by building custom extensions using Forge. The video provides step by step instructions on how to setup a Forge development environment, use the Forge CLI, and render AWS CloudWatch metric and log data in your Compass components, as well as providing source code you can clone to get started.
Resources to get you going
You can check out the entire Developer's Edge video series here. You can learn more about Forge here and Compass here. Link the Bitbucket repo with the apps code is available here.
About your instructor
Warren is a former developer turned technical evangelist who joined Atlassian in 2021. He has worked on everything from COBOL telecoms software running on mainframes to modern cloud infrastructure at AWS. He has a passion for technology and a research background in machine learning. As a technical evangelist, Warren builds awareness of the capabilities of Atlassian products and partner integrations through demos, writings, and videos. He also curates the Developer’s Edge video series (link). In his spare time, you can find him practicing his passion for Brazilian Jiu-Jitsu.
Let me know if you have any questions in the comments!
Warren Marusiak
1 comment
